show identity-management list-precedence
Description
This command displays the order of list-precedence. The default list-precedence is: greylist blacklist whitelist.
Syntax Description
Default
N/A.
Usage Guidelines
Use this command to display the order of list-precedence.
* Switch.97 # show identity-management list-precedence
List Precedence:
1.	Greylist
2.	Blacklist
3.	Whitelist
This command was first available in ExtremeXOS 15.1.
Platform Availability
